[SOLVED] About RTX 3080's possible bottleneck. Please help!
iljinwoo
16
Hello guys, I've recently got RTX 3080.
Now, I've ran couple of games with my system, am suspecting possible bottleneck.
My system:
MSI X570 Mainboard
Ryzen 7 2700X
DDR4 RAM 8GBx2
Zotac RTX 3080 Holoblack
2560x1440P 144hz monitor
I tried to run Anthem in max settings, and I am getting only 60 FPS on freeplay, lowest of 35-40 (I didn't turn on v-sync or frame cap). It does get way better when I enter the hidden places on the map, since my computer have much less things to render but I am not sure if my CPU is the one that is stopping GPU to get to 100% performance.
Any possible reason why this is happening or advices would be appreciated.
Its very possible that's what's slowing you down. You should upgrade to minimum 3200 MHz RAM; 3600 MHz would be ideal.
Update: You were absolutely right, and I was absolutely stupid.
I completely forgot that my ram could go up to 3000 MHz, and didn't enabled extreme profile on BIOS. I never thought slow RAM speed can negatively impact in game performance life FPS.
Though its still lower than what you recommended, but surprisingly, the in-game FPS jumped 20+. Very much appreciated.. I was seriously considering to upgrade my CPU or RAM, and was starting to question myself if it was worth it to buy 3080.
Lesson learnt! Thanks, RTX 2080!
Reactions: spentshells
Yes, the RTX 3080 is a powerful card and needs good supporting components to get the most out of it. You'll get even better results with a faster CPU and even faster RAM, but I'm glad you were able to fix it cheaply/easily. Happy to help!
Reactions: iljinwoo
Yessir. I will upgrade them eventually, but not after spending alot of bucks for 3080.. and that was huge lesson I learnt tonight. RAM is very important too!
Again, thanks for knowledge and... some money saving! I think 2700X will be good for now.
Reactions: RTX 2080
Reason why RAM speed matters on Ryzen is because of something called Infinity Fabric. It's AMD's CPU interconnect which connects every part of your CPU.
It is directly linked to your RAM. Your ram speed reflects the speed Infinity Fabric will run at.
So that's why faster RAM on Ryzen = better overall performance. Slower Infinity Fabric caused by slow RAM will hurt performance a lot.
Infinity Fabric's hardest job is to manage the communication between CPU and RAM, so running both at the same fast speed (1500 mhz or above -- keep in mind 1500 x 2 = 3000 mhz because DDR = double data rate) is beneficial.
Ryzen Master should show your Memory Clock & Fabric Clock:
If not, HWiNFO will do that:
A RAM speed of 3000/3200 MHz is recommended on Zen+, which you have, and on Zen 2 the recommended speed is 3600 MHz. 3200 MHz will still work just fine, the difference is not noticeable as long as RAM speed is over 3000 MHz.
Interesting! So Ryzen's speed is highly impacted by RAM speed right? In that case, does Intel CPU requires high speed RAM like AMDs?
