About to build a new computer. Will the parts in my assembled list fit in the case?
Glorfindel1
30
Here is a link to the list: http://uk.pcpartpicker.com/p/b7pjMp
I'm considering either the Zalman Z11 Neo ATX Case, the NZXT S340 ATX Mid Tower Case, or the Corsair 200R ATX Mid Tower Case case. Open to any suggestions that cost <£60. Please give a reason for your opinion!
Thanks a lot for your time.
Stick with the S340. Miles better than the 200R, Zalman Z11 and many cases that are in a comparable price range.
OR you could make minor changes and switch to an even better case with a just-as-good for the build power supply. The B2 750w is good enough for GTX 970 SLI if you plan to add another, and you can still overclock aswell.
I suggest this for the same price:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£229.98 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£24.95 @ Aria PC)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard (£100.00 @ Aria PC)...
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory (£40.82 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£32.40 @ Aria PC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (£269.99 @ Aria PC)
Case: Fractal Design Define S w/Window ATX Mid Tower Case (£69.95 @ Aria PC)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply (£64.98 @ Novatech)
Total: £833.07
Generated by PCPartPicker 2015-08-06 14:41 BST+0100
However, you are missing an SSD in your build?
Another thing, the Hyper 212 Evo is good but the Cryorig H7 costs the same and is even better and more silent on high fan speeds. Check it out:
https://www.alternate.co.uk/Cryorig/H7/html/product/1174912
@maddogfargo OK, thanks for the info, that's very helpful.
@RCFProd I have an 80gb SSD which I will migrate from my old (dead) pc to my new one. Thanks a lot for your list, I will definitely look into your suggested changes. Also, I appreciate your suggestion regarding the CPU Cooler, I will also look into that now.
The Cryorig H7 seems to have a fan rpm capability that is 400 less than that of the Cooler Master Hyper 212. Will my build be unaffected by the reduced fan-cooling potential, or is that last 400 unnecessary for me? Cheers.
Latest posts
