About to put my 1st rig together, after abit of advice first.
E17_Hammer
34
Ive just recieved all my parts for my 1st go at building my own rig. I'll be putting it together tomorow. Ive got the Coolermaster HAF case and i was wondering where is the best place for the PSU at the top or bottom? If its at the bottom that means that the fan is facing down, is this correct? Also my cpu cooler looks massive, i bought the titan fenrir.
Thanks.
yeah the case is massive, i was more worried about the cooler fitting the mobo, ive got a ASUS P6T SE. Im sure itll be fine though.
My case has a filtered vent on the bottom if your PSU has a downward facing fan. Mine does not, but if it did. Also some people will install their PSU upside down so that the fan points into the case.
