AC Adapter for Seagate external hard drive 1tb
RyanPH
27
i have seagate expansion external drive.
S/N: 2GHMMWYH
P/N: 9SF2A4-500
having a problem with the ac adapter and no more power after years of using it.
it was wa-18h12 ac adapter:
input: 100-240v - 50-60Hz 0.5A Max
output: 12v ---- 1.5A
if i buy a universal ac adapter would my external hdd will work out again?
thanks for the help and sorry for the english!
R_1
Judicious
Herald
RyanPH
27
thanks sir for the info :D it helps a lot for deciding what would i buy.
will work with 12v --- 2.0A? or may harm my external hdd?
R_1
Judicious
Herald
make sure you get one that allows you to select the Voltage and the Amperage.
you should be able to set it to what you need.
https://www.amazon.com/SoulBay-Universal-Switching-Selectable-Electronics/dp/B01N7RS0NG/ref=pd_sbs_23_1?_encoding=UTF8&psc=1&refRID=1GYYG1D8B2VPFMT2PXKT
this one mentions that it supports 12V at 1.5A
RyanPH
27
thanks sir for your help :D
Similar threads
