So I hear a lot about how ethernet cables outright beats net speeds for wifi.The question is, is it worth the connection?
For example if i'm going to expect maybe 5-10% increase speed boost then I wouldn't think I should relocate my entire computer into another room so I can hook it up via ethernet.
My speed as of now (with wifi) is http://www.speedtest.net/result/7039113592 and I use the AC wifi built in the motherboard https://www.amazon.com/Optimization-ROG-STRIX-X99-GAMING/dp/B01F854U8E
For ethernet I have a CAT 6 and CAT 7 on standby.
Should I switch to ethernet and if so does it matter which ethernet cable I used (CAT 7 is an extra cable given to me, so if I can afford not opening it if the difference isn't too big then I rather not).
p.s I do regularly download / upload large files and participate in gaming from time to time.
Thanks for the help folks.
