Hello,
I had zip tied my +2 pcie power cable out of the way when my GPU required dual 6 pins but now my GPU requires an 8 pin connector, unfortunately when i was cutting the +2 pcie power cable away from the zip tie it made an cut into the outer rubber coating, if i look closely the wire is exposed very slightly, is this dangerous, the computer is still running fine under load, and any way is should attempt to repair it, and how this will affect my 7 year warranty.
Thanks,
Zdos123
Thanks,
Zdos123
