P Prabasha Honorable Nov 15, 2016 18 0 10,510 Dec 11, 2016 #1 I've accidentally put 8 pin cpu to 8 pin vga card now pc not booting up i know my psu is gone any one think same happened to the gpu? Mob has one 4pin connector Gpu asus 960gtx This is one of the foolish thing i have did so sad
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,731 1,824 159,590 Dec 11, 2016 #2 More than likely you fried the graphics card to , but won't know till you can test it with another system or PSU. Upvote 0 Downvote
P Prabasha Honorable Nov 15, 2016 18 0 10,510 Dec 11, 2016 #3 Tomorrow ill test my mob i hope its ok Ill have to wait till next weekend to test my gpu i think it also gone so sad Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,731 1,824 159,590 Dec 11, 2016 #4 Hope for the best...Sorry to hear this bad news. Upvote 0 Downvote
P Prabasha Honorable Nov 15, 2016 18 0 10,510 Dec 11, 2016 #5 According to this guy most certainly my gpu gone also mob http://superuser.com/questions/1000679/i-plugged-an-8-pin-eps-cpu-cable-into-the-gpus-pci-e-port-is-it-damaged Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,731 1,824 159,590 Dec 11, 2016 #6 I know , but hopefully you have a better result. Upvote 0 Downvote
P Prabasha Honorable Nov 15, 2016 18 0 10,510 Dec 11, 2016 #7 Psu checked with this method result fan not working http://www.howtogeek.com/172933/how-can-i-test-my-computers-power-supply/ Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,731 1,824 159,590 Dec 11, 2016 Solution #8 Then it is probably not viable....Sorry Upvote 0 Downvote Solution
P Prabasha Honorable Nov 15, 2016 18 0 10,510 Dec 12, 2016 #9 Mob working now its time to check gpu Upvote 0 Downvote
P Prabasha Honorable Nov 15, 2016 18 0 10,510 Dec 12, 2016 #10 Thank god my gpu works only psu affected Upvote 0 Downvote
