Accidentally swapped Power SW and Power LED, is my PSU fried?
Gellaquin
Commendable
Dec 12, 2016
Accidentally swapped the power switch and power button LED connectors on the motherboard, and after fixing it, it only turns on for a tenth of a second, then turns off. Is the PSU fried?
UPDATE: I discovered that the PSU was busted in some way, and installed a different one, and it works just fine now. Thanks for all the replies.
highly doubt it.
so what ur saying is u just put the computer together and tried to turn it on.
psu twitched for a sec then turns off.
found that u had ur power switch connected to the led terminal and led to the power switch terminal on mobo?
iso more info please
id check all connections from the psu.
check cpu
