Accidently added 1000mhz to memory instead of 100mhz on my 1080ti.
NiBy
99
was running heaven benchmark and accidently added 1000mhz to the mory clock instead of 100 on msi afterburner. have i done any damage?
card: asus strix 1080ti
always increase the frequency only with small steps at one time during OC to fin the stable point.
If you made a jump by mistake, simply reset everything ASAP.
For OCing graphic card, I would first only start with gpu proc frequency, power limit, etc.+do not touch the VRAM freq yet until you maxed the gpu frequency, etc. while maintaining it stable.
If you have done this, not those settings down on a paper, just in case you would loose them. You can start fiddeling with the VRAM freq now.
yea as soon as it happened a bunch of artifacts appeared. i seem to of fixed it.
