Accuracy of CPU temp monitoring programs
UncleDaddySwiss
101
I've been doing some maintenance on my gaming PC lately, and have been watching CPU temps with both MSI Command Center and HWmonitor, and this morning HWmonitor is reporting a Max temp of 36C, 37C, 34C, and 37C (Core 0,1,2,3 respectively) and Package 37C. In Command Center I've never observed it going over about 31C. I was wondering how accurate either of these programs are. These are idle temps. I'd like to know which program, or other program if need be, to trust. I've only had the computer running about 15 minutes so far.
Nice cooler.
What's your ambient temperature?
Idle temperatures aren't very critical, but load temperatures are.
Core Temp and Real Temp are accurate. Real Temp was developed specifically for Intel processors.
Core Temp - http://www.alcpu.com/CoreTemp/
Real Temp - http://www.techpowerup.com/downloads/2089/real-temp-3-70/
You might want to give this a read: Intel Temperature Guide - http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
CT :sol:
I know there are a lot of sensors, but the ones I'm looking at on HWmonitor are under CPU.
Also, for a while now the current temps are hovering between 26C and 29C. Doesn't make sense to me.
Edit: Ok also I have another question: I want to check CPU temps under load, so I can tell if I need to reapply thermal paste. What is a good way to do this? I'm not overclocking as I dont have a need for it at this time, but I want to check that my CPU isnt getting to hot.
Nice cooler.
CT :sol:
