Acer 32 Inch 4K display Intermittent vertical lines or artifacts?
brianch777
4
Describe your system:
AMD Graphics Card
AMD RX 580 Sapphire Nitro+ 4Gb
Desktop or Laptop System
Desktop system
Operating System
Windows 10 64bit with the latest windows update.
Driver version installed
Radeon Software Crimson Edition 17.11.2
Display Devices
Single Display, Acer BM320, 32 inch, 4K display, 3840 x 2160 @60Hz over DisplayPort
Motherboard + Bios Revision
Asus P8Z77-V, BIOS Version/Date: American Megatrends Inc. 2104, 8/13/2013
CPU/APU
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 8 Logical Processor(s)
Power Supply Unit Make, Model & Wattage
Cooler Master Silent Pro M2 620W
RAM
Amount of memory installed 16GB
Describe your issue:
I recently purchased a new monitor, the Acer BM320, and a new graphics card to output 4K as indicated above, but sometimes while I am viewing my desktop with nothing open or sometimes when I am watching a video on YouTube or even when I’m typing documents on Word, I would see a group of vertical lines appear for a brief second on 1/4 of the screen. This happens on either the left or right side of the screen and doesn’t happen often. I researched this problem and thought that it might be with the cable, so I went and purchase a certified DP cable and the problem still occurs. It even occurs over HDMI. I even returned and replaced the graphics card and it still happens.
I’m at a loss. Unfortunately, I can’t provide a picture because it only happens for a second and it is not reproduceable. This problem also happened with another monitor I purchased and returned because I thought it could be monitor related - an LG 32 inch 4K monitor.
Does anyone have any experience with this?
I found this article on reddit. It sounds similar to what I am experiencing.
https://www.reddit.com/r/hardware/comments/3hng5a/warning_to_prospective_buyers_of_32_4k_monitors/?st=jablzjoq&sh=52efcd9c#bottom-comments
I was getting the exact same issue when alt-tabbing and running any kind of video. Unfortunately it was my Radeon GPU and not my monitor. Not sure if it was a hardware or a driver issue but I'm on Nvidia now without any issues.
Thats is interesting to hear. Someone on another forum mentioned some problems with amd and 4K and a similar problem to me.
I'm actually going to purchase an Nvidia card soon to see if that changes anything.
May I ask what monitor you are using that had this problem?
