Acer aspire does not power up
tashkoosmanoski
I have acer aspire f5-572 i buy it in 2016 that's about 1 year ago ... i played dota 2 and it just shut down i did open te laptop remove te battery chek the addapter plug it in red light turns on but the laptop does not power i remove the ram leave it for some time pushed the power button for 50 sec put the ram back power it on still nothing the blue light just comes up everytime i press the power button and the coller starts and turns off the same second can someone help me fix this i search online about this but i cant find anything sorry for my bad english
Try the following and see if it will turn on...
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds.
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop. You may also want to try charging it when the device is off, rather than on. If it works then, the cord is probably the issue.
Should that not be the problem, then check the battery to see if it needs replacing.
NOTE: While the battery may be complicated to get to, it should be replaceable. Unless it is under warranty, then you should contact the manufacturer.
