Acer Aspire E14 not turning on but charging. blue power light not lighting up.
Junior_14
Commendable
Jan 5, 2017
I shut down my laptop after work. Upon arriving home, i tried to turn it on but it's not responding. I charged it and the charging light lights up. I charge it until it's full (blue light) and pushed the power button. power light does not light up. laptop nat staeting. help!
Try the following and see if it will turn on.
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds and see if the device will turn on.
5. If it does, great, if not yet, no big deal. Now plug back in the power/charger cord. (If it didn't turn on without the cord in, it should turn on once you it is in. Yes sometimes they will turn on, or try to turn on, even with nothing attached/plugged in.)
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if...
Should that not be the problem, then check the battery to see if it needs replacing.
proteusguy
Unfortunately you cannot remove the battery on the E14 without voiding the warranty. My son's has this exact same problem. Will have to take it in for service I think.
Oct 19, 2018
