Acer E 15 startup and shutdown problems
Alexander_80
Commendable
Dec 12, 2016
I have an Acer E 15 laptop and I am having some problems which I can not explain. I also tried searching online for a solution but it seems I cannot find someone else in the same situation as me.
Okay, the problem is that my laptop just won't start by pressing the power button only once. I have to press it several times, sometimes even hundred of times to get it started. Also sometimes it just won't start until I remove the battery, keep the power button pressed for 5 minutes and then try again by pressing the power button hundred of times.
Also another problem is that when I shut it down it doesn't completely shut down. The screen goes black, the fans stop for 1 second and then they start again and again while the screen remains black. At this time I just give up and keep the power button pressed to shut it down.
So yes, I would really appreciate if someone could help me out solve this problem.
Thank you.
