J jdkeit Reputable Feb 5, 2016 2 0 4,510 Feb 5, 2016 #1 I recently got a new case which has a different pin set up from the stock acer predator g3 case. I need help figuring out which ones go where, I am aware that white = negative and the colored will be the positive, but I'm not sure the order.
Solution cin19 Feb 5, 2016 If your MB is the Intel B85 LGA1150 MB, and it has the standard connectors, and here is the Front Panel I/O Connectivity Design Guide http://formfactors.org/developer/specs/A2928604-005.pdf But make it easy to read here is the layout. http://i.fixya.net/uploads/images/ghost2233_2.jpg And if those wires are this then the white will be negative.
cin19 Titan Mar 14, 2011 15,722 218 112,340 Feb 5, 2016 Solution #2 If your MB is the Intel B85 LGA1150 MB, and it has the standard connectors, and here is the Front Panel I/O Connectivity Design Guide http://formfactors.org/developer/specs/A2928604-005.pdf But make it easy to read here is the layout. http://i.fixya.net/uploads/images/ghost2233_2.jpg And if those wires are this then the white will be negative. Upvote 0 Downvote Solution
