Acer netbook aspire one battery not charging
Welcome to Tom's Hardware Forums,
There are a number of posible reasons, the most likely (most common) is the battery has died and needs to be replaced. That is easy to test with a voltage meter.
It is possible your power jack is broken - does the unit run when plugged into the wall? Does the battery charging light come on when plugged in?
There are a few other possibilities but those are the first to check
Hope it helps
Similar threads
