I just bought an Acer Predator G3 and a new Samsung UHD Monitor .
However, I have problem connecting the Acer Predator G3 to the UHD Monitor.
I used HDMI Cable to try and even DP cable but nothing seems to appear on the UHD monitor.
I tried using my laptop to connect HDMI cable to the UHD monitor and it works .
I then tried connecting the Acer Predator G3 to a normal monitor using VGA port and it works.
I tried connecting the Acer Predator G3 to my TV via HDMI it doesn't work , but my laptop can work.
Please advice on what should I do
