I'm pretty much at my wit's end here.
I have an Acer XB280HK 4K G-sync monitor that out of the box displayed 3840x2160@60hz.
Now this morning out of the blue the monitor started outputting only 24hz. I have searched through the internet and found little to no other problems like this one.
Things I tried :
-Creating a custom resolution with 60 hz with nvidia control panel. Once "created", it doesn't even appear on the selection. and everywhere it still says it's at 24hz.
-Change the refresh rate in Windows in the screen resolution menu.
-Look through the monitor physical options menu to see if anything could be changed there
-Updated drivers (368.39)
-Changed the display port on my GPU.
-Also checked the see all resolution options, and none of them offer 60hz.
GPU is a GTX 980ti
I'm pretty much ready to hear anything from you guys, thanks for any help you guys are ready to give.
Just a quick edit, I plugged my monitor into another PC with a GTX 680, and while it was defaulted to 24hz, I was able to change the refresh rate in nvidia control panel and then in the windows screen resolution menu.
Things I tried :
GPU is a GTX 980ti
