G
Guest
Guest
In a recent build, I used the aforementioned Gigabyte motherboard, with the onboard HD audio, however I/O ports are pretty scarce. In order to achieve a 7.1 speaker configuration, all information points towards a need for a front panel control, with the additional ports I require. Can anyone recommend a good front audio panel control. Could a Sound Blaster Audigy control panel be compatible? If, so, I suppose, I would need a PCI I/o card to control the front panel. What connection, would I use to the MB, to interact with the on-board HD audio? I am a bit at a loss here and would welcome any advice.
