[SOLVED] Achive more than 3600Mhz on B550-E Gaming Mobo?
Maybe, maybe not. Ram clocking higher is never a guarantee. Remember you have to keep your chip in a 1:1 ratio, with the ram, which means you will have to up the speed on the infinity fabric too. If you won the silicon lottery, you could maybe push to 1900, on the IF, for 3800mhz ram. Frankly, it isn't worth it. If you really want to play with ram, for more performance. Look up the Ryzen Dram calculator, and learn how to use it. You will gain more from timings, than speed alone.
Reactions: Nemesia
