So I'm looking to upgrade my system with a modest Overclock to both the CPU and GPU however my current issue is heat. Now this is due to only having the stock cooler and stock case fans installed at this time, but I now have a little bit of money laying around (around £80) and I am looking to buy a H60 and some decent case fans. I have already purchased a 120mm fan which I was planning to install on the side panel, but it is not yet installed. So I have a few questions about the H60 and the correct fan configuration.
1) How much better is a dual fan set up on the H60 (push/pull etc) than the just standard one fan?
2) My case is the HAF 912 plus, I have a 200mm intake on the front and 120mm (stock) on the back as exhaust. What would be the best fan configuration (including the H60)?
3) If I do go for the dual fan setup on the H60 shall I replace both as well as the stock that already comes with the H60?
Lastly if you have any personal favorites and suggestions for which fans I should purchase, would be much appreciated, many thanks
Specs:
Cooler Master HAF 912 Plus USB 2.0 ATX Case
Asus M5A99X Evo R2.0 Motherboard
AMD FX8350 Black Edition 8 Core Processor
Sapphire AMD 7850 2GB
Cooler Master 650w 80+ PSU (RS650-ACAAE3-UK GX-Series)
Corsair 8GB (2x4GB) 1600MHz CL9 DDR3 Memory Module Kit
WD Caviar Green 1TB SATA III 6GB/s Internal Hard Drive 3.5 inch
LG GH24NS90.AUAA50B 24x SATA
Specs:
