acrobat display problem
thanks herc08 for your response
i have a laptop and a desktop computer, i used the monitor as a second display for my laptop.
that is happening when i open a pdf on my desktop computer
yes i used my desktop monitor as a secondary monitor for my laptop
yes it happens with every pdf file
If you click the full screen view option, then exit the program, then open it again, it reverts back to the same view? Is there a default view option in the program?
hi hang-the-9
i tried go full screen then exit, didn't change anything.
i tried everything possible like the software preferences "restore last view" even reinstall and program repairs and registry delete
nothing fixed it.
i have to open each file then go full screen close then open to get it right. but with new files it opens minimized like in the screenshot.
