Activation code for MSI motherboard? Help!
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.action,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.systems,comp.sys.ibm.pc.misc (More info?)
I had a problem with a homebuilt PC with an MSI motherboard. It's a K7T
Turbo 2 MS-6330 v5.X ATX motherboard, with an Award BIOS, and it's running
SUSE Linux 9.1.
I left home awhile back, shutting off the computer. When I returned and
tried to start the computer, it wouldn't. It just wouldn't switch on.
I took the machine to a repairman. He told me that this kind of motherboard
is designed so that you can reset the BIOS by pushing the power switch of
the computer in a certain pattern. He did this and the computer started
running. I took it home and couldn't get it to start, but I called him
back and he told me what to do. Once again, the computer started.
I have checked the manual for my motherboard, but it says nothing about
this. Have any of you ever heard of a pattern of on-off switching that can
somehow reset the motherboard? If so, please drop me a line. Thanks.
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.action (More info?)
dang why you need an activation code ??
Cowly the Game player
Please click on my links
http://spacefed.com
http://gc.gamestotal.org
http://uc.gamestotal.org
http://aw.gamestotal.org
http://www.gamestotal.org
http://3700ad.gamestotal.com
http://www.spacefederation.net
http://www.gamestotal.org/news/
http://ballmonster.gamestotal.com
http://www.spacefederation.net/manual/
http://gc.gamestotal.org/i.cfm?p=aboutgc
http://uc.gamestotal.org/i.cfm?p=aboutgc
http://www.gamestotal.org/corp/
http://www.gamestotal.org/strategygames/
G
Guest
Guest
> SUSE Linux 9.1.
[snip]
Why don't you start by going to the MSI website and contacting Support?
http://www.msicomputer.com/
Andrew
2,439
On Sat, 23 Apr 2005 23:57:31 GMT, Hiawatha Bray <watha@monitortan.com>
You might mean CTL-ALT-Delete which I think restores the default BIOS
settings or something. Why you are asking in this group I have no idea
though.
Andrew, contact via interpleb.blogspot.com
Help make Usenet a better place: English is read downwards,
please don't top post. Trim replies to quote only relevant text.
Check groups.google.com before asking an obvious question.
Andrew
2,439
Oops, sorry, I don't know why I type CTL-ALT-Delete, I meant the "Ins"
key.
G
Guest
Guest
>SUSE Linux 9.1.
Nope. When you say it doesn't come on, do you mean that no fans spin?
If so, buy a decent power supply, yours obviously isn't up to the
task.
G
Guest
Guest
I thought taking out the CMOS battery for 20 seconds or so achieved the same
thing?
Qv
27
"Briarroot" <woodsyl@iwon.com> wrote in message
news:116n76sidfb183b@corp.supernews.com...
> [snip]
I think contacting MSI support is easier said than done.
In my case, I discovered that my MSI video card was misbehaving because they
had flashed it with the wrong BIOS. I sent them several emails and posted on
the MSI forums, but never received any response. Eventually, I just modified
another manufacturer's BIOS and fixed it myself.
G
Guest
Guest
>thing?
It's that kind of talk that got us all killed by Skynet.
