Active Directory C# help
laserpp
356
Hello All,
Writting a new C# program to replace a very old VBS file. Pretty much the program will go through our AD and get all the users and their emails and put it in a CSV file. I found some basic code and ran it and I think it worked because I saw a huge list in the console but when it was finished it closed and gave me an error.
ERROR
System.ArgumentOutOfRangeException was unhandled
Message="Index was out of range. Must be non-negative and less than the size of the collection.\r\nParameter name: index"
Source="mscorlib"
ParamName="index"
StackTrace:
at System.Collections.ArrayList.get_Item(Int32 index)
at System.DirectoryServices.ResultPropertyValueCollection.get_Item(Int32 index)
at ConsoleApplication4.Program.Main(String[] args) in C:\Users\jsalina\Documents\Visual Studio 2008\Projects\ConsoleApplication4\ConsoleApplication4\Program.cs:line 26
at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
InnerException:
Code
Code:
using System;
using System.DirectoryServices;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace ConsoleApplication4
    class Program
        static void Main(string[] args)
            DirectoryEntry entry = new DirectoryEntry("LDAP://OU=PHF Users,DC=phf,DC=inc");
            using (DirectorySearcher ds = new DirectorySearcher(entry))
                ds.PropertiesToLoad.Add("name");
                ds.PropertiesToLoad.Add("userPrincipalName");
                ds.Filter = "(&(objectClass=user))";
                SearchResultCollection results = ds.FindAll();
                foreach (SearchResult result in results)
                    Console.WriteLine("{0} - {1}",
                        result.Properties["name"][0].ToString(),
                        result.Properties["userPrincipalName"][0].ToString());
Any thoughts on it?
P.S. That just the basic code, trying to get it to work in the console before I add the CSV file and validations. Pretty new to this type of programming.
Did you try digging into name like you did with cn? Also, double check what permissions are setup as AD may not be sending that info as you may not be allowed to see anything except names.
That is a good point Sunius, this was the the others guy who was teaching it names, I want to connect to the Ldp.exe and connect the the AD and get the exact names. Just new to this so want to ask boss to make sure I dont mess anything up in the company.
and majestic pretty new at this, All i know from college is basic c++ and java.
That's fine. Was just pointing out that I didn't have to do any custom LDAP parsing or building my own AD interaction objects. Just keep in mind that you'll only have permissions to do what the .Net machine account has rights to do within AD. I would strongly suggest you set up an account with which to impersonate for AD interaction even if it's a user with only read rights.
Here's the current code that is giving me an error. Just want it to work so I can move on and code the other things I need.
Code:
using System;
using System.Linq;
using System.Text;
    class Program
                ds.PropertiesToLoad.Add("cn");
                ds.PropertiesToLoad.Add("mail");
                        result.Properties["cn"][0].ToString(),
                        result.Properties["mail"][0].ToString());
Your problem is that you're assuming a state that isn't true by trying to go for the first element in the Properties collection when doing as you have done clearly doesn't have a first element. You can dig in and find out this info for yourself and I highly recommend it. Debug the result object to see what the Properties collection looks like and adjust your code accordingly.
If the Properties collection looks nothing like you'd expect then your premise about how that object works is wrong and you'll need to examine why.
I am so confused, let me try to walk through the code and see if I understand it correctly.
1)We open PHF Users directory in the AD and set that path to entry.
2)We create a search of that directory using ds.
3)We then say we only want to Users Name and Email and set a filter to only grab Users
4)Then we set a search off all the data and put into results
5)Go through all the results only pulling out the CN and MAIL categories
Are you saying that the results are pulling every single category not just the CN and MAIL? (ie. accountExpires,badPasswordTime,badPwdCount......ect)
I'm saying you're treating your 5th step in a way that's not meshing with how the results object actually works. You need to hook up a debugger and dig into the Properties collection to see how that object is being populated, if at all, and to adjust your code accordingly. Maybe the key name is different, maybe there is no element 0, etc. These are things that will become evident once you hook up a debugger.
ok bare with me, I am pretty new at this debugging. Found the results and PropertiesLoaded and its saying its a string[3], [0]="cn" [1]="mail" and [2] ="ADsPath"(which idk what that is) Could this be the problem?
so many collapsable menus, i went to:
result->Properties->PropertyName->non-public members->["cn"]->value->base->non-public members->list->non-public members->_items->
[0] "vault system"
[1] null
[2] null
[3] null
was that totally useless?
Ok I got rid of that other code and followed another coder on YouTube, his code seems to work, getting all the names, but when i try to add the mail component it errors, gonna work on in a little and ill be back
Code:
            var dc = new DirectoryContext(DirectoryContextType.Domain);
            var d = Domain.GetDomain(dc);
            var s = d.FindDomainController().GetDirectorySearcher();
            var f = s.FindOne();
            Console.WriteLine(f.Path);
            Console.WriteLine(f.Properties["cn"][0]);
            Console.WriteLine(f.Properties["mail"][0]);
            Console.ReadLine();
This works fine for me. Perhaps try getting your searcher object using this method instead?
