I had to buy 4-pin molex to 6-pin pci-e connector, as I had one less pci-e connector for GTX 560 ti
4-pin molex to 6-pin pci-e connector normally they look like this :
https://www.google.co.in/search?q=molex+to+pcie+adapter&espv=2&es_sm=93&source=lnms&tbm=isch&sa=X&ei=LKU6U_boDoSCrAe36oEI&ved=0CAgQ_AUoAQ&biw=1920&bih=955
(2x molex to 1x 6-pin pcie adapter)
But I got the different one and I want to know would it help my GTX 560 ti to run properly?
Its some what like this:
http://www.avadirect.com/images/items/MSC-ADR-MLXM26PPCIE.jpg
It has only one molex of 3 pins. 2 pins have 2 wires each coming out and 1 middle pin have 1 wire coming out. (5 wires total)
Now as you see the picture : http://www.avadirect.com/images/items/MSC-ADR-MLXM26PPCIE.jpg
according to the photo my pci-e side has 3 wires connecting 3 points near the clip....
The above side; in the top- middle and on the top-right 2 other wires connect. (5 wires total)
But for top -left corner a wire from middle comes out and connect to the top-left....
now is this thing wired correctly? Have i brought the correct adapter or is it not going to work.
