Adapters for 21:9 1080p monitor
ra1n1ngbr1ck5
35
Currently I'm looking to purchase this 21:9 1080p monitor:
https://www.amazon.co.uk/gp/product/B01BV1XB2K/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
However I am unsure of what adapters I will need. My Radeon 7850 has 2 mini display ports and a display port, a HDMI 1.3~ port (which I'm not sure works with a 21:9 1080p monitor) and a DVI port.
Specs of my GPU for display outputting:
http://www.amd.com/en-us/products/graphics/desktop/7000/7800#
Any help would be appreciated too. Thanks in advanced
Your GPU has a HDMI port so there is no need for an adapter. The HDMI port will work without any issues with that monitor. 21:9 is not a problem for HDMI.
On AMD page you linked it states: HDMI - Maximum resolution: 4096x2160 @ 30 Hz
So that is way above what your monitor can produce.
@30hz is my issue
In that case get this: https://www.amazon.co.uk/CSL-Displayport-adapter-transmission-products-Black/dp/B015FM3SRE
But, first test your GPU and monitor with an HDMI cable without an adapter. That 30hz is for the resolution stated. At 2560x1080 your GPU might output at 60hz and an adapter would be unnecessary.
EDIT: First link was for an adapter capped at 1080p. Fixed it, the above adapter will work without any issues. I am using something very similar to connect from onboard display ports for some workstation machines onto 1080p monitors that have HDMI/VGA only.
Thank you very much for your help. Just after placing the order. I'll keep you posted and see if it works.
Your welcome!
