Question Adata XPG GAMMIX D30 16GB 3000Mhz OC to anything above 3333Mhz is possible through DOCP ?
Led zeppelin blues
156
4
10,595
Hi ,so i tried Overclocking the mentioned RAM in the title to above 3333 Mhz using the DOCP on my Asus Prime B450M-A Motherboard running a Ryzen 5 3600
But anything above 3333Mhz ,it wont post , the system will restart a few times and go into safe mode where i have to reset the bios
I've never Overclocked RAM before and was quite curious if this was the limitation of DOCP and manual overclock would be needed or do i update my Motherboard BIOS which would help achieve it ?
Edit - Updated Bios , still the same
Ryzen is running on stock no OC if that matter ?
Or is it the motherboards max capability ?
Please guide me so i can understand better with your help
Thanks
