ADB problem when installing SuperSU on Galaxy S6 Active
Where fix root bat file is present. Right click anywhere(just not on files) and select "Open command window here"
on command windows type "fix_root.bat"
If that doesn't work again open command window in same way as above and type all "adb" related commands manually
like,
Code:
adb push G890A /sdcard/
if you get error this time show me that.
So your phone model is G890A?
What android version you have?
I am unaware of the recovery file it is using.
When you run FIX_ROOT.bat, right click on it and run as administrator.
If it doesn't works try replacing "/sdcard/" with "/storage/emulated/0/"
If it doesn't works, instead of pushing G890A, paste contents of G890A into your internal storage by PC and delete that push line from bat file. Reboot to recovery and try again.
@echo off
cls
echo --- µÈ´ýÉ豸Á´½Ó
echo
pause
adb shell cp -R /sdcard/supersu /sbin/
adb shell cp /sdcard/install-su.sh /sbin/
adb shell /system/bin/sh /sbin/install-su.sh
adb reboot
pause
that you script... pause meaning after he has end run... he leave cmd session open... you can upload pic of that screen.
use please that new script i had change for you
cls
echo --- To start install Press Enter.
echo
pause
adb reboot
pause
1 last thing, open folder G890A in you pc, edit file install.sh, copy and paste here. I am want to see what script do.
Yes
5.1.1, people in the forum said that it would work with the 5.0.2 root files
http://www.mediafire.com/download/3zz9l6gf5753jjc/Recovery_COMBINATION_G890A.tar
Didn't work for me, unfortunately. :??:
kohwall:
you kidding?? See Here...
I ran your script and got this: http://image.prntscr.com/image/a87c494475b1433b949e4591...
you try to copy that folder from C:\Windows\system32... the folder there?
I will give you a full solution and end with that.
here the script
cls
echo
pause
adb push %~dp0G890A /sdcard/
adb reboot
pause
next... install that.
https://androiddatahost.com/upload/M1b9d
and last thing.
put the folder "G890A" beside fix_root.bat and check if all that file exist in "G890A" (supersu and install.sh)
run end enjoy.
like,
Code:
This worked. Thanks to both of you! Now I'm trying to flash gapps with no luck.
