• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Add 2nd fan to U14S, or extra case fans
Jun 5, 2020
75
On a PC with Noctua U14S, Meshify C case, Ryzen 3950X cpu.
The Meshify C comes with a single 120mm intake fan on the front. And a single 120mm exhaust fan at the rear. The front has space for 3x120mm fans, or 2x140mm fans.
Would it be better to:
  • replace the front case fan with 2 NF-A14s?
  • add a second NF-A15 to the cooler?
Phaaze88
Illustrious
Ambassador
Umm, neither?
If the Meshify C already has 2-3 front intakes and a top and rear exhaust, then there's not much to be gained from adding or replacing fans.
Adding a 2nd NF-A15 won't change much there either.
Now, if you just want to do the above just to do it... hey, no one can stop ya.
Jul 2, 2020
43
I have a Meshify C case with 2 120mm Fractal Design Fans in the front for an intake and 1 in the rear for an exhaust. I have a R5-3600x with the NH-U14S cooler. I added the second NF-A15 fan in the pull position and it lowered the CPU temp by 1 to 2 degrees. It's something, but not a lot. However, with the higher heat load from the 3950X, you should see a little more temperature drop.
Phaaze88
Illustrious
Ambassador
Power limits aside, the Ryzen 3000 cpus will push for higher frequencies - however slight - when they are given more thermal headroom, much like Nvidia's gpus.
Intel's cpus don't behave in this manner; you'd have seen a larger drop in thermals with a cpu with similar power draw.
Reactions: glennhl
Phaaze88
Illustrious
Ambassador
The the above comments imply that if I add fans, then the temperature won't drop much, but the clock speed might go up a little?
Yes.
Just the high thread count loads though. Your 3950X will still hit 4.7ghz on light loads - it may gain another 40mhz over it's current attainable frequency in heavy loads.
According to this, adding 2 AF14 fans to the front dropped CPU temps by 7 degrees, but that was on an i7-6700k CPU:
https://www.gamersnexus.net/hwreviews/3061-fractal-meshify-c-review-vs-define-c#:~:text=Although our review of the,the GPU from cooling adequately.
The frequencies on Intel's cpus aren't affected by power and thermal headroom, except for the power and thermal limits.
Thread starter Similar threads Forum Replies Date
T Cooling 3
SaLtRedkiller Cooling 4
