Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi -
First off, I confess to flying by the seat of my pants. But hey, so what. I
like learning new stuff.
I installed a Maxtor ATA 60 gig drive from my old system into this new Dim
8400. The IDE channel has only a DVD drive so a put the hard drive as drive
1 on the available connector (set to cable select).
Well, it works but I noticed video playback from the drive was stuttering.
Investigating, I found the drive is operating in PIO mode (with 'DMA if
available' set). Tried removing/reinstalling the Primary IDE Channel driver,
but NG.
Further investigating - Maxtor site says I should be using an 80 pin ATA
cable, otherwise I might get what I'm seeing...OK, but the Dell literature
says the IDE connector on the main board is 40 pin!
I did see this question posed here (adding ATA HD to IDE on an 8400), but I
don't recall seeing a post about how it turned out. Well, I tried it and
that's where I'm at - PIO mode.
Am I S.O.L.?
TIA- John
Hi -
but NG.
Am I S.O.L.?
TIA- John
