Add more tilt to VESA mount
LilDog1291
313
I bought this to mount my second monitor above my first: https://www.amazon.com/AmazonBasics-Premium-Single-Monitor-Stand/dp/B00MIBN16O/ref=cm_cr_arp_d_product_top?ie=UTF8
The reason is that my new monitor is an ultra wide and due to space constraints my second will really only fit above the first on a wall mount. The problem is that the viewing angle isn't the greatest and the Amazon Basics mount doesn't tilt the monitor downward enough for my liking.
Has anyone ever found an adapter to add additional tilt to a VESA mount? If not does anyone have any clever ideas for me to try?
It's simply a limitation of that mount. I would get another one that tells you how many degrees it can tilt.
