Adding a Second Power Switch to my Computer
zvolzz
4
I want to attach an additional power reset switch to my computer so that I can continue to use the existing one on the front of my case and have an additional one up on my desk. My motherboards manual says the power switch is a "ATX power button/soft-off button (2-pin PWRSW)". I had hoped to buy a splitter cable so that I could simply plug in an additional switch.
I have looked and there doesn't seem to be cables you can buy for this purpose. Will I have to split the cable manually? Or am I just looking for the wrong thing?
I have found many 2-Pin Computer Case Fan Power Connector Y-Splitter Adapter Cables but I don't think this is what I want.
What would be the best way to accomplish this? If necessary I'm open to soldering something but I would prefer to buy something ready made so I don't screw it up.
Reactions: RokeyKokey
I think what you have above is correct, but this:
So my best bet might be just sauder the black wires and the red wires to each other and wrap them? I saw the other question before posting but I was worried doing that might be a bit sketchy.
Cool. So it should be as simple as this?
[pre]
| | black on/off
red | | +-------------------+
| |on/off| |
[/pre]
Latest posts
