What is the easiest way to cut a side panel so that I can install a spare fan to blow right on the CPU? This is an Elan Vital T-10 case. I have power tools, Dremel, etc. to do the hole, and could probably do it cleanly enough to drill a bunch of 1/8 inch holes and epoxy screws so that the side does not look bad... Any site related to case mods that has done something like this? I really don't want to spend $100 for a cool case that has a side fan.
ST
ST
