Adding a wireless connection to a linksys wireless network with a motorola modem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
How do I add a new wireless connection (computer)to my present linksys wireless network with a motorola modem
If the computer presently lacks a wireless adapter, get one (PCI or USB for desktop PCMCIA or USB for laptop).
If it has one have a look at any utilities which came with it or go to Windows Networking and see if the adapter is detecting your wireless router's signal. If it is but not connecting most likely you need to tell it the wireless security passphrase. That should be be visible in the router's user setup screens (see router manual for how to access them).
