Ok, so im build a computer for my uncle. very cheap around 300$ for everything including the OS,
the case im using is the zalman zm t2 plus here (http://www.zalman.com/global/product/Product_Read.php?Idx=865)
the only problem is i need to add an 3.5in optical bay drive for a micro sd reader he can access from the front. My options are either get a different case which isn't much fun, or mod the zalman( i was already going to put 2 extra top fans on it ) and try to cut through the front panel and create a stable slot in the case attached the already existing 5.25in bay.
if any one has already tried this or seen videos of people trying this i would appreciate the link or opinion. THANKS 😀
System specs
Kingston HyperX FURY 4GB 1866MHz
AMD A4 7300
Seagate 1 tb HDD
MSI Computer Socket FM2+/ AMD A68H/ A&GbE Motherboard Micro ATX/ A68HM-E33
Lepa MX-F1 350W ATX Power Supply
windows 7
System specs
AMD A4 7300
Seagate 1 tb HDD
windows 7
