Adding and deleting shortcuts to right click
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
If you right click on the desktop you get the options, new as well as
shortcuts to certain programs. How do I add other programs to the list
of shortcuts & delete those that won't be used?
Thanks in advance
Templates
[[When you right click and select the New menu, certain files can be created
automatically. This list allows you to delete certain types as well as
create new types.]]
You can use TweakUI.
Download TweakUI here >>>
Microsoft PowerToys for Windows XP
http://www.microsoft.com/windowsxp/pro/downloads/powertoys.asp
Tweak UI
TweakUI.exe
Tweak UI for Windows XP Guide
http://www.winxpsolution.com/Tweakuixppro.aspx
Add items to the New menu (aka ShellNew entries)
http://windowsxp.mvps.org/shellnewadd.htm
Add or remove entries in the New objects list (ShellNew)
http://windowsxp.mvps.org/shellnew.htm
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:OZOA4fbsFHA.2880@TK2MSFTNGP12.phx.gbl,
the Old Fart <nothere@optusnet.com.au> hunted and pecked:
> Thanks in advance
