Hello there!
I'm planning to add another fan(120mm with an adapter) to the cpu cooler Xigmatek Loki SD963, which has now 1 92mm fan. I've searched the internet and I'm a bit confused which one should I take as it will be on the front site and the already installed 92mm fan will be mounted at the back side.
I have an Aerocool VS-9 Window case with:
-2x front intake fan
-1x back exhaust fan
-1x side intake fan
I was looking at Corsair SP120 and AF120 performance series.
Are there any other fans which you would recommend?
Thanks for your help!
-1x side intake fan
