Adding External Power to Usb 3.0 hub???
Mar 8, 2018
4
Hello everyone! I want to add external power source to my usb hub. I will do it like this>> https://www.youtube.com/watch?v=0tEVCaaNVJQ&utm_campaign=DonanimHaber&utm_medium=referral&utm_source=DonanimHaber
But there is a problem. This video shows adding power to 2.0 usb cable but i want to do it for 3.0 hub. My hub has 10 wire connections. This is the hub>> https://drive.google.com/open?id=12dYJa98zyb4rLj3FjpTzf4tSN4Up8yqd I want to add external power to 2.0 and 3.0. If you need hub's datasheet>> https://goo.gl/uyyJBe Please help me. I will be very grateful if you help. Have a nice day!
https://goo.gl/rZsV65 – this goo.gl shortlink has been disabled. It was found to be violating our Terms of Service. Click here and here for more information about our terms and policies respectively.
The first link is inaccessible, and the second one brings me to a datasheet for a USB hub chip. Are you building the hub for yourselves?
And the video is not relevant, I suppose.
I updated the link. Please check again. And i don't building it myself, just i am adding external power to it.
This picture shows just a connector, with (probably) both USB and Ethernet connection. I can't tell where this connector goes, and messing with it has a high chance of damaging something you know nothing about.
A 3.0 USB hub with power supply is like $30. Get one of these, and power whatever you want to be powered thru this hub.
Thanks for your advice but i want to do it myself. I will use a diode so i will not harm my pc but maybe i can harm the hub and plugged device. If i cut the red wire and add a diode there then add power supply to red and black, will it work?(as in the video)
