Adding LED fan to CRYORIG H7
assassin445522
1,355
Ordered the corsair crystal 570X, wanted my CRYORIG h7 cooler to have the same an LED fan that syncs with the case (sp 120 RGB from corsair)
I just want the same performance but with an LED fan, for looks only
I would remove the old fan or could I use two?
I don't think the H7 is designed to hold 2 fans and I don't think you need 2 for it.
as for the Fans, they both have similar performance but Corsair doesn't mention their lowest RPM:
---------------Cryorig QF120----Corsair SP120 RGB
Air Flow:--------49 CFM----------------52 CFM
Noise:-----------25 dBA ----------------26 dBA
Speed:----------330-1600 RPM------1400 RPM
