Adobe Flashplayer update installation problem
stratcat
Commendable
May 10, 2016
7
I have no problem downloading the update, but when I click on the icon in my downloads, nothing happens. The hourglass doesn't even appear. Using windows XP. Where do I go from here?
maybe xp is not supported on any latest updates ? it sees Xp and just don't do anything that's how it is anymore on things as that ?/
now yopu could go to adobe and download there uninstaller uninstall the flash you got then reboot and let it auto reinstall when it see you don't have any flash installed and then it should give you the most updated one for XP use ??
https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
something in your old flash maybe hanging up the works so try a fresh start ???
Thank you for your reply. It's working great now. When I start working again in August, I plan to upgrade this other Dell I found and install 7 on it. But until then... Have a good day
