Hi! I recently built this machine for exclusive Adobe suite use (Premiere Pro, After effects and Photoshop):
Core i7 7820X
Corsair H115i Water Cooler
EVGA SuperNova 850W Gold 80plus
Mobo ASRock X299 Taichi (bios 2.00)
64GB DDR4 Crucial 2666 RAM
ASrock GTX 1080TI Strix OC
1TB M2 NVme Crucial (for OS and software)
512 GB M2 NVme WD black (for scratch and projects)
OS: Windows 10 pro 64-bit (updated)
Nvidia driver: Latest update (April 2018)
From start the system was extremely unstable using Adobe software. Several crashes, BSODs and so on.
I researched a lot on forums (PugetSystems, Adobe, etc) and found that I should set the CPU Vcore to 1.2000V and set Adaptive mode to Enable. The BIOS of my board does not have obvios names for these settings, but I tried some settings and the system just keep crashing.
The only settings I found to be reasonable stable were to set all turbo (intel turbo boost and turbo boost 3.0) to off and the cores to 3.6GHZ.
Anyone with similar hardware has the same issues?
Thank you very much for any information!
Some sources of information I researched:
https://www.pugetsystems.com/labs/support-hardware/WHEA-UNCORRECTABLE-ERROR-on-Gigabyte-x299-and-Skylake-X-SOLVED-1042/
https://forums.adobe.com/thread/2380232
Users with MSI X299 MBOs are saying the latest BIOS update solved this issue. I sent this to ASRock, asking for help, but was just ignored. I have the latest bios on my TAICHI X299 and it keeps crashing.
Thank you very much!
Core i7 7820X
