Question Advantage using DP 1.4 on 1.2 monitor?
Yzf60rr
Commendable
Mar 26, 2017
7
I’ve searched and understand they’re compatible, but I haven’t read if it’s worth upgrading.
I have a Viotek gn34c Ultrawide. It came with a DP 1.2. I bought a DP 1.4 but didn’t realize the monitor only supports 1.1 or 1.2.
Will there be any benefits to using the 1.4 if monitor doesn’t support? It was only 12$ on Amazon, but I’d rather return it if there’s absolutely no point.
Thanks
Yzf60rr
Commendable
Mar 26, 2017
7
There is no benefit as that's a 3440 x 1440p @ 100Hz max monitor, and DP 1.2 is good at that resolution to ~110Hz.
The DP 1.4 on your RX580 and that cable could extend that to 200Hz, but your monitor can't do that.
Thanks for the explanation!
