Hey, I just joined this forum because I need some advice on building a new pc. I always wanted to build one, but never got the chance because I thought you had to be a brainiac like Dexter from Dexter's laboratory with a lot of time on your hands. So I've finally made a decision and saved enough of my hard earned money to build a BUDGET gaming pc. I only have around $700 to spend and I don't want to send more than that unless I HAVE to. I already have a cheap CRT moniter (upgrade later), keyboard, speakers, and mouse. I did spend a lot of my time researching for the past month about computers so you don't need to inform about that confusing stuff because I know the basics. This is what I have on my wish list so far on newegg, so could you please tell me if everything is good to go or if I should get something different with better deals and performance for the same amount of money. Oh! I also plan on overclocking because its a budget machine and I want to play crysis on decent settings(monitor only does 1280X1024).
Computer Case and Power Supply combo:http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.164037
Processor:http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
Ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
Motherboard:http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
Hard Drive:http://www.newegg.com/Product/Product.aspx?Item=N82E16822136161
DVD Burner:http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Video Card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814102822
Operating System:http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
Cpu Fan: I need help on a cheap fan with great cooling power
This build will cost $642 with shipping so I can add a little bit more to make it come out to $700 with shipping. I believe thats everything I need to get started. Any help and advice would be greatly appreciated.
