Build Advice Advice for $1,000 to $1,500 Build Upgrade
kdays62
4
Folks,
Back in January 2014, I built my first computer. It was used for gaming, work, photos, YouTube watching, etc. I have made some upgrades in the last 6+ years. The current configuration is listed below. I am seeking some advice on my current upgrade configuration. The advice I received 6 years ago was very helpful, so I am returning to the well again.
I am would like to get some advice on the upgrades that I am thinking of making to my current system. I have between $1,000 and $1,500 as a budget. I’d like to keep some of the existing components to keep the costs down. I have identified the new components in the upgrade configuration. The new system will be used to play games, watch videos, surf the internet, etc. I am simply looking for the upgrade to keep the system in good shape for another 4 to 5 years.
Thanks in advance for your help!
Current Configuration
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Asus Maximus VI Hero ATX LGA1150 Motherboard
Memory: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM 1600 (PC3 12800)
Storage: Samsung 860 EVO 1TB 2.5" Solid State Disk, Samsung 850 EVO 500GB, Western Digital Caviar Black 2TB 3.5" 7200RPM; Western Digital Caviar Black 1 TB Hard Drive 3.5 Inch, 32 MB Cache, 7200 RPM SATA II
Video Card: ASUS ROG STRIX GeForce RTX 2060 Overclocked 6G GDDR6
Case: Corsair 750D ATX Full Tower Case
Power Supply: Seasonic 850W 80 Plus Gold ATX12V/EPS12V Power Supply - X-850 SS-850KM
Operating System: Microsoft Windows 10 64-bit
DVD: ASUS BW-12B1ST/BLK/G/AS 12X Blu-ray Internal Burner Drive
Monitors: ASUS PB278Q 27-inch WQHD (x2); Acer T232HL bmidz 23-Inch Touch Screen LCD, ViewSonic VX2452MH 24" 2ms 1080
Keyboard: Razer Huntsman Elite Gaming Keyboard Optical Switches - Chroma RGB Lighting - Magnetic Plush Wrist Rest
Mouse: Razer Basilisk v2 Wired Gaming Mouse: 20K DPI Optical Sensor - Chroma RGB Lighting - 11 Programmable Buttons
Gamepad: Razer Tartarus Pro Gaming Keypad: Analog-Optical Key Switches - 32 Programmable Keys - Customizable Chroma RGB Lighting
Proposed Upgraded Configuration (New Items are bolded and italicized)
CPU: AMD Ryzen 7 3700X 8-Core, 16-Thread Unlocked Desktop Processor
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition CPU Air Cooler, Anodized Gun-Metal Black, Brushed Nickel Fins, RGB Lighting
Motherboard: ASUS ROG Strix B550-E Gaming AMD AM4 (3rd Gen Ryzen ATX Gaming Motherboard
Memory: G.SKILL Trident Z Neo Series 32GB (2 x 16GB) 288-Pin RGB DDR4 SDRAM
Storage: Samsung 860 EVO 1TB 2.5" Solid State Disk, Samsung 850 EVO 500GB,Western Digital Caviar Black 2TB 3.5" 7200RPM; Western Digital Caviar Black 1 TB Hard Drive 3.5 Inch, 32 MB Cache, 7200 RPM SATA II
Case: LIAN LI LANCOOL II MESH PEROFRMANCE BLACK Tempered Glass ATX Case
Happy to hear any feedback!
ScrewySqrl
Champion
If you can hold off for about a month:
the Ryzen 7 4700X or 4800X Will be available (late oct/early nov). You can skip the cooler, as the r7s already come with an excellent cooler that already has RGB.
I'd go with Patriot Viper 16 GB of DDR4-3733 CAS 17, which is the sweet spot for speed for the 3xxx series, and only about $99
Consider a 3070, due out next month over the 2060, for only about $100 more than a 2060 SUPER, about $150-200 over a 2060, and considerably more performance
The 850W PSU is overkill. You could use a new 3090 with a 650-700W PSU, 550-600W for the 3070, 500W for the 2060. If you already have it, keep it though...PSU's are overpriced due to short supply.
ocer9999
Depends on what you are doing with the rig but 32Gb is a lot of memory, I would put that to a better CPU, the new ryzens are coming in oct...
For the price the ROG is a bit over priced, I would suggest a Steel Legend which is pretty good features and good quality VRM.
