Build Advice Advice for a build
Sep 29, 2020
16
Hello, this is my first post in here, hope you are all doing great, i'm looking for an advice on a build, i was thinking on a Ryzen 5 3600 CPU, but other than that i don't know which parts will work together with that CPU, or if there is other that i should consider, my budget is like 900 to 1000 USD and i hope that with this budget could build a mid tier gaming pc, at least to play some titles at 1080p, but i will like to have room to buy a pair of headsets because the current one i have is broken and will need a new one, thank you in advance for your response and hope you have a great day.
helper800
I would do something like this:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($204.99 @ Newegg)
CPU Cooler: ARCTIC Freezer 34 eSports CPU Cooler ($44.99 @ Newegg)
Motherboard: Gigabyte B550 GAMING X ATX AM4 Motherboard ($129.99 @ B&H)
Memory: Team T-FORCE DARK Za 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($106.99 @ Amazon)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive ($104.99 @ Newegg)
Video Card: Asus GeForce GTX 1660 SUPER 6 GB Phoenix OC Video Card ($229.99 @ B&H)
Case: Fractal Design Meshify C ATX Mid Tower Case ($98.98 @ Newegg)
Power Supply: Antec Earthwatts Gold Pro 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($94.99 @ Amazon)
Total: $1015.91
Generated by PCPartPicker 2020-09-29 12:54 EDT-0400
Sep 29, 2020
16
is there a way to squeeze in a build with the ryzen 5 3600 and a MSI Gaming Radeon RX 5600 XT on a similar budget? or the gtx super will be the same performance while being cheaper? just wanna make sure i get the best i can for the money, this is my first decent budget build and don't wanna go wrong because is a little bit hard for me to save the money, thanks in advance for the response
helper800
This is really the best I can do while still useing decent parts:
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($204.99 @ Amazon)
Video Card: Gigabyte Radeon RX 5600 XT 6 GB GAMING OC Video Card ($289.99 @ Newegg)
Total: $1075.91
Generated by PCPartPicker 2020-09-29 19:56 EDT-0400
A balanced gamer will budget about 2x the cost of the processor for the graphics card.
I might suggest a i3-10100 for $120, a B460 based motherboard $70 and a stronger graphics card like a $300 GTX1060ti.
You might want to initially use the intel integrated graphics if the rumored RTX3060 should launch soon.
Here is a review of the i3-10100 which holds it;s own against the R5 3600X
https://www.techpowerup.com/review/intel-core-i3-10100/15.html
