Question Advice for a build
xDeluxers
34
Should I buy a new PC, what components should I get on a $ 1000 budget?
At the moment I have the following components in the list:
CPU: Ryzen 7 2700x
Motherboard: MSI B450 Pro Carbon Max WiFi (I need it with Wifi)
RAM: Corsair Vengeance RGB Pro 16GB 3200Mhz
GPU: NVIDIA GTX 1660 Ti
SSD: Samsung 860 EVO 500GB
HDD: Seagate Barracuda 1 TB
Case: Corsair iCue 465X
Are these components ok or can I find better for $ 1000? I will use the PC primarily for gaming
CPU: Ryzen 7 2700x
  • You can't have a pc without a power supply and you didn't list one.
  • Why do you want a hard drive? Get a 1TB m.2 NVME drive.
  • You're over-spending on the case for this type of build. There's some very nice cases for a lot less cost.
https://pcpartpicker.com/list/TXyxF8
PSU: Seasonic Focus 650W 80 Plus Gold
GPU: MSI 1660 Ti Gaming X
I use the hard drive to store data such as videos, images, audio and some games.
