Advice for a relative novice on my second build
sparky1248
7
I want to build a new system to replace my original build. I don't have a lot of money to work with, but I'd like it to last a few years, so I dont want to go cheap.
APPROXIMATE PURCHASE DATE: ASAP
BUDGET: ~ $600
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Internet Surfing, Moderate Gaming applications (flight simulators, kids games, etc.)
PARTS NOT REQUIRED: DVD drive, keyboard, mouse, monitor, speakers.
PREFERRED WEBSITE(S) FOR PARTS: NewEgg, Tiger Direct or Mwave (open to others)
PARTS PREFERENCES: None.
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: unknown
ADDITIONAL COMMENTS: The case does not need to be fancy... form over function.
I have a Freezer 7 Pro heatsink, so a socket 775 would save me money on buying a different heatsink, as long as I'm not sacrificing speed.
Thanks for your help. You guys give out a lot of great advice!
xthekidx
Splendid
Dec 24, 2008
3,871
Lots of problems...back to the drawing board.
xthekidx
Splendid
Dec 24, 2008
3,871
Here is my suggestion:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=9019125
You can combo the PSU and Case for $20 off. The PSU you could go cheaper on if you wouldn't upgrade this build later on and just get a 380w Antec, which also comes in the same combo. The reason I chose the 500w is because it will allow you to upgrade to a more powerful GPU that needs 2x6 pin connectors if you decide later on that you need more graphics power.
Th3Sm0kingM4n
16
$60 COOLER MASTER Centurion Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152
$60 Seagate 500 GB HD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
$90 Powercooler HD 4830
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131129
$70 Corsair 450 Watt PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
$45 GSkill 4 GB DD2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
$95 Asus P5Q SE PLUS Mobo (P45)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131347
$120 Intel Core2 Duo E7400 2.8 CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206
$100 Vista 64 OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
Total: $640 +Shipping -Rebates
You can overclock with your current cooler and you'll be set for a while. Probably want to upgrade the GPU at some point down the road, but this build will do what you need.
xthekidx
Splendid
Dec 24, 2008
3,871
Ok so the PSU you chose is garbage (best used as a doorstop)...very low quality and fails often. Failing PSU=Big Problems. Mobo you chose is low quality (ASRock is not a good mobo company) and cheap...Its not a component I would skimp on because everything goes through it. Seagate 7200.11 drives have huge firmware problems which causes failures constantly. The CPU you chose is nice, but is more expensive than the E5200 and the differences in the two can be made up easily by overclocking. The GPU is good, but the only way you can afford it is to go cheap on other more essential components. Since gaming is a secondary priority and he has a $600 budget, an HD 4830 is plenty.
jcknouse
447
Hm...okay.
I have used ASRock in AMD and they have worked fine. Never had an issue with them. Didn't know they were considered bad.
The Raidmax PSU had 3/4 5 egg reviews. Figured it was pretty good for the money and had plenty of power that it wouldn't be stressed by that CPU and single GPU.
I thought the 7200.11 issues were with the 1TB and bigger drives. My bad I guess.
I thought about suggesting a low-end (sapphire 4850) and getting a little better PSU, but I figured he didn't want a bottle neck.
I get what you mean tho. Thanks for letting me know. :)
P.S.- I gotta check my drives in the machine I just built. Can't remember if I went Seagate or WD 500GBers. :(
Chance
I just built a system to replace my wife's rig that was about 10 years old and on its last leg. I didn't have a huge budget either. In fact, I was trying to spend only between $300 and $400.
My wife uses her computer to browse the internet and edit digital images in Photoshop, so I was able to cut a lot of corners. I already had a keyboard, mouse, and monitor too. Like you, I also tend to stay away from flashy cases--and being that I wasn't planning on using this rig for heavy apps or gaming, I didn't bother buying a noisy case with 4 fans.
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=6532389
Total Cost w/ S&H+Tax = $392.55
So far it's run great. My only complaint is that I skimped on the power supply and while it runs the system fine, it definitely is not shielded very well and it seems to interfere with my wife's cheap set of speakers. They now emit an annoying buzzing sound whenever the computer is on whether they are plugged into it or not. I'm buying her a new pair of quality shielded speakers because she is a music fanatic and her old pair are probably older than her ~10 year old computer.
If you already have quality speakers then go for it, if not you could dish out more money and buy a good PSU and case seperately. Th3Sm0kingM's suggestions are aesthetically pleasing, good quality, and inexpensive--however they cost more than twice as much as the case/psu combo I picked.
Hope this helps (if you haven't built it yet).
