[SOLVED] Advice for Cheap Web Browsing Computer for my Elder Mother
dpeel
174
7
18,695
Last week a lightning surge took out my Mother's Desktop Computer I had fixed up for her from an old system of mine. I've got a case, power supply....need to buy a CPU, Motherboard and DDR4 Memory. I'm thinking about using a AMD Athlon 200GE which should eliminate the need for a dedicated graphics card and a Gigabyte GA-A320M-S2H Motherboard. I'd probably only put 8 gigs of DDR 4 in it as my mom will only be using it for web browsing, email, printing, etc.
Any advice or comments would be appreciated...trying to do this as cheaply as possible. I'll use the hard drive that's in the old system as it seems to be ok.
^ With the above said you would have to decide it it was right for you, but I have had exceptional good luck over the years getting refurbed a and b grade laptops from Newegg. Be wary of the ratings and reviews of "sold by" just as you would on Amazon and the like.
Indeed.
I got burned with an OS license on a laptop I bought last year.
Newegg, and a 3rd party seller.
That's why the one I linked was "Sold by Newegg, Shipped by Newegg".
Reactions: punkncat
Please tell me where I can look at this option.
Do an eBay search on (for instance) Optiplex 3020 SFF. Look around in the areas of 30xx, 70xx, 90xx as the model number, then the second set, like 10, 20, 30 is indication of the generation it's built on. Be sure to read the deets on it being a licensed copy of Win 10.
Edit, for instance, first return is $50 without Windows...$95 with.
If you've already got the case, power supply and storage, then I'd probably recommend the following:
PCPartPicker Part List
CPU: AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor ($87.99 @ B&H)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ Best Buy)
Memory: G.Skill Aegis 8 GB (1 x 8 GB) DDR4-3200 CL16 Memory ($31.99 @ Newegg)
Total: $234.97
Generated by PCPartPicker 2020-06-27 21:29 EDT-0400
Note that the processor is only $15 more expensive than the Athlon 200GE and going with the MSI B450 "Max" series, there's no need for a BIOS update.
-Wolf sends
Total: $234.97
-Wolf sends
Looks pretty good. A little more than I was hoping to spend but looks like it's worth it. Do you know off hand if the motherboard bios would have to be upgraded for this cpu?
? Why wouldn't it need bios updates? I would suppose that the CPU is old enough that this board would recognize it? Just found a CPU compatibility chart and the CPU is listed. I'm getting ready to order the parts and I thank you for your input.
Just ran into a problem....the motherboard isn't in stock after all.
Seems that is the case.
Given you're already over budget and the next lowest priced motherboard is $100 more expensive (if it's in stock), I'd say either hold off on this or go in another direction.
-Wolf sends
yes...that's my observation at this point. I would be willing to buy a used AM4 Motherboard from someone who has the ability to flash the bios to the latest so the cpu would be recognized by the cpu.
Total: $234.97
-Wolf sends
Well, I decided to buy these parts....I had to pay slightly more ....got the cpu from Best Buy and the MB and Memory from Newegg. I also decided to buy a 500GB WD SATA SSD as the old hard drive probably needed to be retired. I'm looking forward to putting this together for my 91 year old mother. She already misses having her computer.
Reactions: Flayed
