I have a very old machine which uses a Pentium 4 2.8 Ghz chip with 1 gb DDR2 667 ram.I would like to upgrade it a bit by changing the mobo/processer/ram on ultra low budget of around 145$.The best I could find at my budget is -
MSI H61P20 (G3) / Intel Pentium G2010 / 4 gB ddr3 1333 mhz
It gives a total of around 146$. I have tried all compatibility terms and found this the cheapest suitable which has a future option of upgrade to i7 and a pcie 3.0 slot. Also found that the mobo itself hasn't integrated graphics - sucks from the cpu. So it won't be a problem as far as G2010 is concerned ? any better options in that budget - no elastic budget.
