Question Advice for CPU given a specific GPU/Motherboard
Oct 28, 2020
Hi there,
First time posting here, I hope I do it right.
Could anyone give me some advice for a CPU upgrade and if it's worth it?
Here are my specs:
Motherboard: Asus p8z77-v lx
CPU: I7-3770k
GPU: geforce 1080
Using bottleneck calculator I see I have a 25% bottleneck due to the cpu: https://pc-builds.com/calculator/Core_i7-3770K/GeForce_GTX_1080/0020Uulu/8/100/
Given I don't want to change the motherboard and the GPU, what would be a good CPU to upgrade to? Since I use my pc for gaming, would I see a big difference in performance if I had no bottleneck with a better CPU?
Best regards and thank you in advance,
Frog eater
Hi there,
Here are my specs:
CPU: I7-3770k
GPU: geforce 1080
Frog eater
Using bottleneck calculator is not accurate, in fact it's total crap but you already have best CPU for that MB
Oct 28, 2020
Thank you very much. Just saw the processor compatibility list and you are right. Would it be wise to change my motherboard and cpu to get more out of my geforce 1080?
